Group devices into projects
Jirka Krepl shared this idea 2 years ago
Under Consideration
Good idea would be to group devices into projects.
If you use Pybytes in company, then you can group add devices to projects your company is working on.
You can then see notifications for devices in your group, update firmware for devices in the group.
Comments (2)
Yes, the main problem is to be able to deal with a large amount of devices "bond" to a single user account (some companies might use hundreds of devices), so the idea would be to let the user create different projects inside Pybytes. Each project should group up the devices that are related to each other, according to their purpose or location or whatever the user decides.
Another good thing about the projects system would be to let the user invite specific collaborators inside each of his projects. So he can have different teams dedicated to each project, to help the primary user to manage all his devices efficiently.
There are other things to say but I think this can give you a good overview of the whole idea.
I live the idea of being able to group and then also limit access to those groups. This can be for collaborators or customers potentially.
Yes we want to do it in this way:)
